Polygon- / Oval-Grinding
Tool sort cycle
  • Producing high precision oval and und polygon geometries with grinding – tolerance class IT5*
  • Easy parametrized definition of the geometries based on DIN 32711
  • Perfect complement to technology cycle Polygon- / Oval-Turning
  • New machining opportunities for more innovations on the part – e.g. shaft-hub connections.
  • Position-oriented polygon and oval geometries due to 6-sided complete machining advantages
User Interface
Left: Pre-position and support position in X and Z-axis can be directly entered over the surface. / Right: Monitoring of the support position via a defined Position window.
Machine types
Controls
